urgent please help please read
pickinganame
Post by pickinganame »
my car will niot start i replaced the disturbutor 2 times already and it work eached time i did it but now its not working its getting fuel to the engine it wants to start but it just wont please someone help yes it gets spark :mad:
mzdspd
Re: urgent please help please read
Post by mzdspd »
if u have a stock intake make sure the resonator is on. it won't start if its not on.
pelado
Post by pelado »
Pull the plugs, clean them off, and dry them out.<p>Reinstall, try again.<p>Got any codes?
mirage-mx3
Post by mirage-mx3 »
maybe it does as mine , plugs getting soaked all the time, i have to pull out fuse for injectors and crank starter for about 10-15sec and then it will start.. i hope i can find a soultion to this pretty soon :p
mazdamaniac
Post by mazdamaniac »
Why would you pull the injector fuse?
Just press the gas pedal all the way to the floor (like it says in both the owners manual and shop manual, if you bother to read them).
This cuts out the fuel delivery during cranking and introduces a lot of dry air into the engine.
You can clear a flooded motor in just a few cranks that way.
mirage-mx3
mazdamaniac : yes i do bother to read the online manuals and i'm aware of the pedal to the floor thing to not send any more fuel to the engine but this is not working for me :< , it dosen't mather how long i crank the starter with the the pedal floored.. the plugs are still all wet and the only thing i can do to get the car started then is to pull the fuse, crank it 10secs and then it will start ..
geezMX3
Post by geezMX3 »
I had a similar prob, with the engine not starting and losing power. I was told by mech to replace the crank angle and entire distributor and now it's working fine. Not claiming to know how this helped, but perhaps it will give some ideas to those who do know. (Also, would appreciate your responses, if this was the right thing to do or did I get ripped off)
pickinganame
thanks for all the help i went out this morning after it heaated up in my garage and broom started right up now im confused maybe bad gas inside the injectors? replaced the distubortoe agian but nothing so im stumped hope it dont happen agian //
