timing
Re: timing
Unfortunatly, I dont think anyone will be able to tell you without dismantling their engine as well.<p>It would have been a good idea to mark the position of the gears, belt and flywheel so you could put them back easily.<p>I'm not sure if there are timing marks on the gears or not, but if there were they would most probably allign with top dead centre.<p>Cheers
Psyrg
Psyrg
pelado
Re: timing
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by XxAntwawnxX:
its in the shop manual<hr></blockquote><p>Antwawn is correct, look in the online shop manual. The gears have dots on them that should align where they mesh.
Re: timing
ok thanks the timing was messed up when i got the car but i don't see the marks on the engine just on the gears it is a white line
Re: timing
In the manual it shows you where the marks are located on the engine... Reading will solve all your problems here.. hehe
