This is my first post to the MX-3 community, since I often hang around at PT(Probetalk). BTW I did perform a search and found nothing talking about if a difference does exist between K8 flywheels.<p>I would like to know if the 92-93 and 94-95 K8 flywheels are the same. I'm asking this because after some research I found out that the 92-93 clutch disc is 215mm(8.5") in diameter and the 94-95 clutch disc is 225mm(8.875") in diameter.<p>Are the K8 flywheels interchangeable?
Can all K8 flywheels be used on MX6/PGT transmissions?
Difference between 92-93 and 94-95 K8 flywheel
aaronthehic
Re: Difference between 92-93 and 94-95 K8 flywheel
I have the 92 k8 flywheel and the probe clutch bolts right on. so did the cm stage 4<p>I'm 95% sure that it may work... sometimes
13.023 @ 105 mph
I know that more than a few of us have the Act hdss clutch for a probe/6 your measurements are correct though it is 215 and 225.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
New info!!!!!<p>92-93 flywheels are stamped K801, whereas 94-95 are stamped KS01.<p>So, is there a difference. Somobody in the mx-3 community must know this or came across this issue. Is there a weight diference?
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by mikeseli:
New info!!!!!<p>92-93 flywheels are stamped K801, whereas 94-95 are stamped KS01.<p>So, is there a difference. Somobody in the mx-3 community must know this or came across this issue. Is there a weight diference?<hr></blockquote><p>Does anybody know?
Where have all the K8 experts gone?<p>Certainly somobody must have some info on both of those flywheels?
