Simptoms of faulty o2 sensor....
Hector Gomez
Post by Hector Gomez »
Well since i got my manual transmision mx i have been having a good time...but 2 months ago the car started to lose power, even after getting the whole intake and exhaust, i feel its kinda underpowered. Sometimes when im a WOT the car builds speed and then it starts to lose it and i have a strange gasoline like smell.
By the way its a 92 with 200,535 miles and counting :D (This things are reliable! :D )
Hector Gomez
Owner of the first modded MX-3 in Mexico!
lazzyie
Re: Simptoms of faulty o2 sensor....
Post by lazzyie »
Have you pulled engine codes? Faulty 02 sensors will make you run rich and your gas mileage will go way down.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi :)
cjthor
Post by cjthor »
Is your check engine light on? It sounds like an O2 fault. Try disconecting the battery for bout 15 minutes. See if that helps.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
Mike 94PGT
Post by Mike 94PGT »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by MeXican-3:
...but 2 months ago the car started to lose power, even after getting the whole intake and exhaust, i feel its kinda underpowered. Sometimes when im a WOT the car builds speed and then it starts to lose it and i have a strange gasoline like smell.<hr></blockquote><p>Might be worthwhile having the catalytic converter checked for an internal blockage.
Mike<BR>94 PGT <A HREF="http://home.golden.net/~trinity" TARGET=_blank>Codes, Maint, MAF, PCMs etc...</A><BR>Supermoderator, mx6.com
pelado
Post by pelado »
What kind of gasoline is available in Mexico? Leaded, unleaded, octane?
