Where to mount on engine stand?
IvsD
Post by IvsD »
While looking over the KLZE, I decided that it is best to mount it onto an engine stand using the holes that bolt into the tranny. Now, I am worried about damaging the threads, so I was wondering if anybody knew the size of bolt that is used to mount the tranny to the block. Is this the best spot?<P> [img]shrug.gif"%20border="0[/img] <P>Thanks in advance
IvsD
Re: Where to mount on engine stand?
Post by IvsD »
Ah, and one more quick question. The motor is going into an Escort GT, should I upgrade the fuel pump? Or will the 1.8l pump handle the job?<P>I will be upgrading the fuel system in the future, but for now........
dylanmx3
Post by dylanmx3 »
I used two tranny mounting holes and the two through holes down on the skirt...no probs so far. The tranny holes are an M12X1.25 or 12mm metric fine thread. <BR>Take a look in forced induction I read something in there about the fuel pump being a strong component and good for turbo...just going off memory so don't take it as fact.<BR>Good luck.<BR>Dylan
