ECU Disasters
ECU Disasters
What does it mean, when my ECU gives me a trouble code, for a sensor that does NOT exist on my 1.8l V6??<P>dean.zarrillo@mts.net
Re: ECU Disasters
well what did u use to pull the codes? that might be the prob man. i went to tune up shop twice and i got the same codes twice. i decided not to go with the dealership cus they wanted like 70 bucks just to pull codes. i figured since i didnt have my socks with the handlebars on that day that i wansnt prepared to get shafted.
Live your life a quarter mile at a time!! Payback is a mother!!
pelado
Re: ECU Disasters
It would help if you gave the code with whatever sensor it is that you're referring to.
Re: ECU Disasters
Its gives error p0105:<BR>Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction <P>Two places have gotten this error and DONT knwo what sensor it is pointing too.
- Zoso124
Re: ECU Disasters
Obviously your car is OBDII, and you would think they would be easier to diagnois but there not. Never heard of a MAP sensor on your cars, but the ECU detects the Atmospheric Pressure.
Mike Evans
Gone:
Gone:
pelado
Re: ECU Disasters
There is a barometric pressure sensor on the ECM board (inside housing). New ECM required, I believe.<P>Code 14 on pre-OBDII.<p>[ November 18, 2002: Message edited by: pelado ]
Re: ECU Disasters
If this barometric pressure circuit is gone, what will i notice? b/c My car runs just fine, but the CEL light is on.??<P>dean.zarrillo@mts.net
white fish
Re: ECU Disasters
isn't that in the VAF??
