Thanks but one more problem
JacobsMX-3
My last post I dont know what happend ?!?!?!?!?! explained what my brother did and you guys responded thatnks for that but it wasnt the vaf it was the spark plugs. So I replaced that and put my new air filter together. But remember when I said my brother hit the cone and it busted and we saw a sencer well the scensor is now busted and I dont know were to get one so I was wondering if you guys could help me out again and recomend were to get on. Thanks again!
pelado
Re: Thanks but one more problem
I'll give you all the help you deserve....search.
I'm confused, you broke your spark plugs?!?<P>I'm beginning to lose interest, but whatever you did to your car is serious and expensive. Get together the dough and take it to a dealer. Strike some deal with your bro that he pays for labor or something. Replacing the chip and vaf isn't a time consuming job, but between paying for the chip or paying for the labor, the mechanic will screw you over. If it isn't too hard just buy a new vaf with the chip (or pick one up from a junkyard) and install it yourself.
pelado
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Hy300:<BR><STRONG>I'm confused, you broke your spark plugs?!?<P>..... Replacing the chip and vaf isn't a time consuming job, but between paying for the chip or paying for the labor, the mechanic will screw you over. If it isn't too hard just buy a new vaf with the chip (or pick one up from a junkyard) and install it yourself.</STRONG><HR></BLOCKQUOTE><P>The blind leading the blind. And what is this "chip" that you're referring to?!?!?
David Coleman
Just take the car to a shop. You don't need to touch it anymore.
David Coleman
And so speakith the Lord. Amen
Blake Gibson<BR>'93 Black MX-3 GS<BR>Anyday is a good day if I'm in my MX-3.
