clutch problems help
when I am stopped at a light and have my foot on the clutch my engine revs up to 1500 then drops and then it starts all over again. any help or suggestions are welcome
I am looking into a way to put turbo under the hood and will let you all know how where as soon as I find out
pelado
Re: clutch problems help
There is a similar post already on this topic. Look for your answers there.
do you have it in gear,because i posted a similar problem with mine.<P>look at fuzzy post
fuzzy red mx-3
concretecutter
I know this sounds wierd but everytime my coolant leval is low my engine would do the same thing.Also check for leaks in your intake.
ya know i did have that same problem and when stopped at light my rpms would increase,i just changed my tranny oil to <BR>mt-90 and reset my ecu and it seems fine.<BR>i'm not sure if this is a fix for you,so i hope you can find your fix.
fuzzy red mx-3
