what should the RPM be at while car in "P"
What should the RPM be at while the car is in "P" or "D" while stopped in an auto GS. My RPM is usually at about 300-500 and I get the "CHARGE" light on, but when I gass it and at about 1000 RPM, the light dissapears. I my idle off, should it be set higher??
hi
Re: what should the RPM be at while car in "P"
The idle speed for the 4 cylinder is 700-800 in park, 640-700 for the 6 cylinder. Sounds like you need to adjust it up.<P>Good luck!
COMPACT Gladiator
watch 4 yours belts...and aslo check your altenator. JUST A THOUGH!!
spawn_46375
listen for hissing noises aka vaccum leaks also check your oil cap seal and your make sure your intake hose from ail sensor to the intake has no leaks or holes
92 MX-3 GS<BR>brillant biege<BR>www.angelfire.com/in3/spawn46375<BR> spawn_46375@yahoo.com
I agree with spawns post in referance to the hoses. My baby was idling low with a noticeable hissing sound coming from the front right. It was a couple of vaccume hoses that had come loose. Normal Idle when cold should be anywhere fom 900 to 1200 RPMs and when warm should be 600 to 900. Also make sure that you have regular maintenance done too. Hope I could help and good luck!
Blake Gibson<BR>'93 Black MX-3 GS<BR>Anyday is a good day if I'm in my MX-3.
