Alarm install for MX-3
In september I tried an alarm install in my MX-3 and failed, my fault or bad alarm i don't know. But anyways I managed to get all the wires that I needed and spent hours testing to make sure of the right ones for all the connections to the alarm unit. One thing that I was not sure about and spent hours debating on it is whether the MX-3 uses a positive door trigger or negative door trigger. I ended up using the negative trigger wire from the alarm unit and I have no idea if this was what cause my alarm install to fail.<P>If anyone knows the answer and other tips I'd appreciate it Thanx in advance.
Re: Alarm install for MX-3
yes the mx-3 has a negitive door trigger,so explain your problem and I will tell you what to do to rectify,alarm malfunction is 99%installer,dont take this the wrong way I am just trying to help,if the alarm does not work at all I can give you wiring guide of car and tell you what to attact to what.<P>Mark <BR>KillerMx3<BR>Certified Mobile Install Technician<BR>MECP first class certified tech
Thanx that clears one thing up, I fried the alarm so I dumped the idea of an alarm for now. I only really wanted keyless entry. So now I'm thinking of putting in keyless entry with starter disable since the relay is still fitted to my car. <P>The unit comes with onboard relay for the parking light flash confirmation so I don't need a relay for that wire(White) and I connect it to the red/black wire behind the dimmer switch, is that correct? <P>What other relays do I need? I figure I need 2 (30 amp?) relays for the door actuator, and a relay for each aux. output channel, is that correct?<P>Thanx again
