radiator
radiator
well last week i took out my radiator to clean it i put it back in filled up the radiator with water. while i was driving i look at my tempeture and it was pass the heating temp so i stop and check it out and there was smoke every were. whats wrong??
Pearl-JapSpec
Re: radiator
water?
Car Out Of Order For Now...
2 weeks In counting till re-incarnation!!
New G-Force Front Bumper!!
-_-_-_- Pics On Site -_-_-_-
http://members.cardomain.com/mx3_junkee
- jpwmx3
Re: radiator
Put some Prestone antifreeze with it.
1993 GS V6/402,000km http://images.cardomain.com/member_imag ... 290_18.jpg
kuruption1983
Re: radiator
seems like there is a crack or some hole, or it might be just an installation error you made and the pipe is loose somewhere and lets hot fluid out. water should be fine for the rad, but a bit of antifreeze wouldnt hurt.
- jpwmx3
Re: radiator
You must use antifreeze with water, otherwise the water will just boil from the heat of the motor. Antifreeze works for both extreams, Hot and Cold.
