ignition wiring
ignition wiring
anyone know which of the four wires on the distributor (ignition wires) is the negative wire? Im trying to put a new tachometer in...
gh
Re: ignition wiring
It should be the yellow and blue wire.
That is the tach sensor wire.
If you are looking for a ground, just run it to a ground point. Take a look at this, it may help.
Wiring ID chart
Wiring ID chart
