Swapping motor on a 93 1.6L MX-3
chrisostomos
Hi im wondering which mazda engine should i swap with my friends 93 MX-3 4cyl 1.6L. He is looking to put a mazda 626 turbo engine in it. Would that fit.....is it compatable.
Would i need to switch me Cars computer too???
Any advice would help.
thanks in advance
Chris
thanks in advance
Chris
- atlantamx3
Re: Swapping motor on a 93 1.6L MX-3
no.
Not worth it.
Plenty of info on the site about several available swaps though.
1.8L BP-Turbo
1.8L BP
1.6L B6T
Those will be your best choices fow your 4-cyl.
Before you ask anymore questions-- just flip through the posts and all of your questions will be answered.
Also-- look in the 4-cyl FAQ.
Not worth it.
1.8L BP-Turbo
1.8L BP
1.6L B6T
chrisostomos
i changed an engine a few times before but not with a different engine. Would i have to change the cpu or just the engine??? Will the tranny be compatible??
thanks
thanks
chrisostomos
What about the engine of the same year
130-hp, 1.8-liter V-6
would that fit good....would i have to change the cpu??
- atlantamx3
no-- you should not go from a 4-cyl to a V6. The 1.8L BP has about 125 HP and will be a DIRECT bolt in for you. The BP-Turbo puts down around 190 or so in stock form.
If you decided to get the v6-- you may as well go for the gusto and do the 2.5L KLZE Swap. It will cost you about the same after everything is said and done-- but you would have 200 HP instead of 130.
chrisostomos
thanks a lot for the help!!
Which car and from what year range can you get the 1.8L BP engine??? Will i just have to swap the engine and thats it because that i can do, or will i have to convert other things like the ECU etc???
Thanks again
Thanks again
- jaydog5678
SEARCH function works great...
- dj inferno
[quote]Originally posted by jaydog5678:
chrisostomos
will i have to change the tranny and ECU with that too??
or what other stuff will i have to change
thanks!!
thanks!!
- MX3-Freak
Ok, I hope you didn't ask this question to DJ, because then I got some turbocharged lawn mower for sale you might be interested in.Originally posted by dj inferno:
thanks!!
I.E. a rotary will not fit in mx-3 with out mucho dinero.
Stock 1995 RS - Creek Blue
Car Meanins:
Car Meanins:
chrisostomos
arent people suppos to help in here instead of being sarcastic??
Many of the regulars here are sarcastic basturds, youll learn to love it ...cant blame them, they have seen the same engine compatibility thread 298340928374298374 timesOriginally posted by nhl39:
Save yourself the embarassment and use the search feature, or take a look at Perrys sig about 5 posts north: "***NO-- A ROTARY CANNOT BE PUT IN AN MX-3, SO DON'T ASK!!***"
EDIT: hahah turbocharged lawn mower ....post a dyno sheet
<small>[ May 27, 2004, 01:36 AM: Message edited by: Joe's 94 RS ]</small>
Black 94 RS, Erebuni MS style front, OEM sideskirts, Clear signals, altezza tails, 93 seats, Civic projectors
- guyaverage
Someone ask for a turbocharged lawn mower?..... http://www.industrialnewsroom.com/fullstory/6588
"The answer is: More power. I dont care what the question is."
-Tim Allen
-Tim Allen
- dj inferno
arent people suppos to help in here instead of being sarcastic??![]()
- MX3-Freak
You've got to be joking LOL.Originally posted by guyaverage:
Car Meanins:
Car Meanins:
