well i put the pro lx tranny in with a mx-6 clutch and Fidanza Flywheel and it was pretty easy, just got stuck on rusted bolts and stuff
i did the swap with 2 friends and we get it done in less then 2 days
here are some tips for people doing the swap
put the rear motor mount bolt on backwards, if u don't the shift linkage is gonna hit it and u cant shift into gear
and make sure u get the speedo gear from the pro lx tranny cause the stock one dosn't fit
here are some pics
<img src="http://images.cardomain.com/member_imag ... 6_full.jpg" alt=" - " />
<img src="http://images.cardomain.com/member_imag ... 7_full.jpg" alt=" - " />
<img src="http://images.cardomain.com/member_imag ... 9_full.jpg" alt=" - " /> <img src="http://images.cardomain.com/member_imag ... 8_full.jpg" alt=" - " />
Tranny Swap done
Tranny Swap done
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: Tranny Swap done
thats sweet dude, just got a few questions...
where did you find the tranny, how'd u use an mx6 clutch, how much for the flywheel?
junkyard, but has low kms
the mx-6 clutch and protege clutch are the same but the mx-6 one is alot stronger
i got ripped hard on the flywheel 800 cnd
u can get them for 300 us off ebay
2004 RX-8 - Project
2004 RX-8 - Project
does the mx6 clutch fit on the mx3 1.6 ? if not do any other clutches like the protege lx fit on the mx3 tranny?
www.illegalCustoms.com
Tri-State Area Car Club
