grounding points?
Shady469
grounding points?
Post by Shady469 »
Has any one tried to add additional grounds to the motor? If so, where are the best places to ground? I was trying to look into how the Integra Hyper ground system is run, but I'm leary about grounding the dist. and other electronics.lemme know.
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
Stinky
Re: grounding points?
Post by Stinky »
Basicly with the hyper ground system it's the cylinder head,engine block,frame,chassis,and alternator case.
maldo
Post by maldo »
Run a ground from the -ve on the battery to the chassis, from the intake manifold to the -ve post, MAF to -ve, alternator to -ve/chassis ground, block to chassis, tranny to chassis. You will notice some improvement with 8gauge but 4 is the way to go. You could ground the disty, no harm in that. You want to use similar ground points, run things in a series.
