60 series Flowmaster muffler
Brainless
Post by Brainless »
Hi!<p>Right now I have a custom 2" catback with a straight through muffler and a glasspack as resonator. It produces a powerfull sound which is ok for city driving but for highway, it's an other story (I do 700km of highway every two weeks and I get an headache every time).<p>To go back to a quiet sound without to much compromising performance, I'm thinking about switching back to stock pipes with a more descent muffler. The flowmaster 60 series muffler seem the be the best choice for me.<p>-Has anyone used one of those on their 4 cyl. mx-3?
-What do you think?
Jonathan Michaud
93 Red RS
agomonaco
Re: 60 series Flowmaster muffler
Post by agomonaco »
Did you loose any MPG when you switched. Is your engine a 1.6L?
Brainless
Post by Brainless »
I have a 1.6L and I didn't notice and changes but there probably was a small one.
Jonathan Michaud
93 Red RS
Brainless
Post by Brainless »
anyone?
Jonathan Michaud
93 Red RS
Freq2002
Post by Freq2002 »
What muffler & glasspack are you running now?
I started out with a hi-flow cat, 2" pipe back to the muffler, sounded like a Cesna at anything over 45 MPH. ugh! When I broke the down pipe I got that problem fixed.<p>I put in an entire system in my 1.6L DOHC. 2" pipe from the collector flange on back. A 2.25" flex joint into a hi-flow cat, 24x2" cherry bomb under the seats, back through a Magnaflow dual tip muffler that looks alot like the stock pipes. P/N:14830
It sounds good with a deep mellow tone, not like a 400 lb bumble bee, and was bearable on the highways as well. I did get better milage at highway speeds, & a better top end as well. Great mod if you do a lot of distance driving, best use for these way high geared pigs.
The contents of this post are the opinions of myself and are NEVER meant to be percieved as the "be all, end all". So cram it!! :p
