what's the difference
celedhel
Post by celedhel »
between Coil overs and Lowering Springs??
kuruption1983
Re: what's the difference
Post by kuruption1983 »
basically as far as i understand and from the point that i have only the lowering springs, the difference is that you can change the height of coilovers by using their special wrench, but the height of springs is just not adjustable.<p>wish this helps, :shrug:
