Found some injectors... need some specs on 'em
torpedan
Re: Found some injectors... need some specs on 'em
Post by torpedan »
ask your firend what cc there rated at too. <p>Anyways get a multi metere and measure the resitancee then do so on yoru current set that should help determine if they will want to work together =]
-torp.
I don't own a Mazda.
