idle problem
idle problem
My car will idle at around 2000 rpms. When you're under the hood you can push the throttle and it lowers the idle down to around 1000rpms.<p>What do I need to fix that? What is the best rpm range to idle at?<p>I was thinking new throttle cable/assembly?<p>93 1.6L
