miracle, headgasket on gs sealed itself?
mazdamx3 gs93 razberry ok, i had queries as to why car temp raised, (hose had burst mos.back, had replaced, the lower small coolant hose,)since then car sporadically overheated Bad no coolant lost, temp goes up, steams, I stop til it cools. i drive around my baby! took out the thermostat to circulate, yes, i did flush out, with gardenhose and water, refilled, replaced 2 rad.caps, not the water pump, run ac fans in emergencies to get home, well, now it has stopped, completely overheating, what happened? had acted like blown headgasket with white smoke and all, now it is perfect on 100degree day. What is going on? melanierazberrygs any ideas????
