brakes clicking?
Paragon
brakes clicking?
Post by Paragon »
i noticed that when i come to a stop, once i get to about 20 mph, the passenger side brakes start making a clicking sound that i can even feel a little bit...the slower i go, the slower it goes, so i figured it's either the pad or the rotor...am i correct?
bronzeboy
Re: brakes clicking?
Post by bronzeboy »
I had the same problem, same wheel. I think it has something to do with the caliper. There is a technical recall or something on it that I printed out (it's on here) and took to Midas and they finally fixed the problem for me.
Paragon
Post by Paragon »
thanks man....i was going to pull it off and see if the caliper was loose or the inside sleeve was screwed up...i didn't know there was a major prob. with it, thanks
