To all with a single cam four cyl...........
- cjthor
Can someone look in their manual and let me know what pin 2o is on your ecu? Thanks in advance..
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
- Shady469
Re: To all with a single cam four cyl...........
2O-Airflow <BR>1B-Power<BR>2B-Ground<BR>2E-RPM<BR>2L-Throttle <BR>These are the notes I have for istalling my S-AFC I got from 007Sniper. and remember if you get confused on the pins:<BR>2Y 2W 2U 2S 2Q 2O 2M 2K 2I 2G 2E 2C 2A<BR>2Z 2X 2V 2T 2R 2P 2N 2L 2J 2H 2F 2D 2B<BR>for the left side looking at it head on(tabs on top) and on the right:<BR>1U 1S 1Q 1O 1M 1K 1I 1G 1E 1C 1A<BR>1V 1T 1R 1P 1N 1L 1J 1H 1F 1D 1B
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
- cjthor
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Shady469:<BR><STRONG>2O-Airflow <BR>1B-Power<BR>2B-Ground<BR>2E-RPM<BR>2L-Throttle <BR>These are the notes I have for istalling my S-AFC I got from 007Sniper. and remember if you get confused on the pins:<BR>2Y 2W 2U 2S 2Q 2O 2M 2K 2I 2G 2E 2C 2A<BR>2Z 2X 2V 2T 2R 2P 2N 2L 2J 2H 2F 2D 2B<BR>for the left side looking at it head on(tabs on top) and on the right:<BR>1U 1S 1Q 1O 1M 1K 1I 1G 1E 1C 1A<BR>1V 1T 1R 1P 1N 1L 1J 1H 1F 1D 1B</STRONG><HR></BLOCKQUOTE><P>So what is 2o labeled in your manual? that is what I need to know
Jarid Perry
- Shady469
airflow
- cjthor
Airflow? this cant be what it says.. Does anyone else understand the question? <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Shady469:<BR><STRONG>airflow</STRONG><HR></BLOCKQUOTE>
Jarid Perry
maldo
He is right.<P>2O - Airflow Meter<BR> ignition switch ON - Approx 3.8V<BR> Idle - Approx 3.3V<P>This is straight out of Mazda's Shop Manual for the 1992 SOHC motor. I needed it when I did my swap. If you were looking for some other form of info, what is it?
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
- cjthor
Thanks. It just didnt sound correct to me. I am still trying to find the correct wire on my ecu to get the maf signal. Gotta go to Mazda next.
Jarid Perry
I thought that maf stood for "mass air flow meter" which would be pin 2O, but maybe I'm in over my head.
