Head gasket????
Head gasket????
Somebody told me that my car is liking oil from the head of the engie how can i change it???
92 Mx-3
Re: Head gasket????
are you sure your head gasket is leaking or your valve cover gasket?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: Head gasket????
it is probably the valve cover gasket. I had someone replace mine it was about 200. Give or take.. I would try to do it yourself and save the money.
MrsOzx<p>buh-bye........
Giavonni Perelli
Giavonni Perelli
Re: Head gasket????
I do not know much about car, but sometimes I could see oil around the area were the spark plugs are.
92 Mx-3
Re: Head gasket????
is it leaking above the spark plugs, or near the bottom? if its above all you gotta do is take a socket take the bolts out form the top, theres two that are on the side where the cam cover is, but you gotta drain your oil.. and get a gasket, the gasket just pops in,.. and thers no need for a tourqe wrinch.. put them in tight.
