Test pipes?
Crazed8056
Test pipes?
Theres a company out that offers a product called a Testpipe. Its a straight pipe that replaces your catalytic converter. I wanted toknow if anyone has tried this product and if so, what is gained by using it. Also, what are the possible negative effects of using it. [img]shrug.gif"%20border="0[/img]
Raivynn
Re: Test pipes?
Main reason to avoid removing the catalytic converter..........ILLEGAL. If you have to pass emissions tests......don't remove the cat.<p>[ January 17, 2002: Message edited by: Raivynn ]
<A HREF="http://raivynn.trancegirls.com/" TARGET=_blank>http://raivynn.trancegirls.com/</A>
ProtegeSTS
Re: Test pipes?
dont remove the cat even if you dont have to pass emissions. Its not really worth much power anyway, and it is VERY illegal, even if you dont have to pass emissions.
-93 MR2
#129 E-stock
#129 E-stock
Crazed8056
Re: Test pipes?
Thanks for the help guys, can anyone recommend a good cat-back system, and header for the 4 cyl. SOHC engine?
