FS: Parts off K8 Engine: alternator, tensioner, valve co
Gro Harlem
Post by Gro Harlem »
I have a useless K8 engine sitting in my garage and since I can't sell it whole I am going to part it out. It is nearly complete as of this moment. Here is the list of useful parts:
-"Mazda" valve covers
-K8 Engine cylinder Heads with complete valvetrain & camshafts intact
-Timing belt tensioners & pulleys
-Thermostat housings
-Alternator
-Alternator/AC belt tensioner bracket
-crank position sensor
-Intake manifold
-throttle body
-fuel injectors
-oil cooler assembly
-EGR assembly
-Exhaust manifolds
-Downpipe w/flexpipe
-Coolant sensors
-Oil pressure sender
-Engine block with internals
-dipstick tube
-timing belt plastic covers
Useless parts:
-Oil pan is from my KLZE and was dented in. I had to swap on my K8's oil pan, so the one on the K8 now is useless :(
-Power steering tensioner bracket broke when I loosened it :(
There are other parts I'm sure.
If you want any of these parts, please let me know your offer via PM, email or AIM. Thanks!
DONATE TO MX-3.COM
BADMX3
Re: FS: Parts off K8 Engine: alternator, tensioner, valve co
Post by BADMX3 »
how much for the timing belt tensioner and pulleys, also timing belt plastice covers including shipping to england?
many thanks
msbmx3
Post by msbmx3 »
would you happen to have a 1.8 mtx Starter?
you pm box is full
DJester187
Post by DJester187 »
yeah tried to pm ya but full how much for the clip(and an inch or two of wire on it) to the coolant temp sensor that is near the filler cap on the k8? my mech cut it off and spliced the wires to the sensor next to the fuel rails on my ze, n now (thanks to mdavis) i know how to fix it and need it back. thanks
Electric Black '93 MX-3 GSR, Curved neck KLZE, KL36 ecu, Outlaw Engineering Thermal Spacers, Custom CAI, Carbon Fiber Invader Style hood, 2.25" straight pipe exhaust, custom muffler, lowered 1.8", and a set of 17" Exel DL-46's. With more to come once I get some $$$....
Gro Harlem
many thanks
So you want the pulleys and the lil tensioner strut thingy only? Shouldn't weigh too much or be too big inside of a box, but I'd still need to figure out shipping to england. If you could email me your address or PM it to me. My email is firstgenprotege @ y ah oo.com without the spaces.
DONATE TO MX-3.COM
Gro Harlem
you pm box is full
Sorry, I am using the starter on my MX3 right now. I have a 4cyl starter though ;)
DONATE TO MX-3.COM
Gro Harlem
crap. sorry, i'l empty it now.
So you want the lil green coolant temp plug with metal clip thingy & some wiring so you can splice it? I'm using my MX3's haress, but I might have a spare coolant sensor plug b/c I pulled a spare harness from another MX3 GS at my yard b/c I needed the distributor plugs.
Just lemme know exactly what you want before I start gutting the hell out of my spare harness.
DONATE TO MX-3.COM
DJester187
ok great, here is a pic ( i hope) yeah just need some extra wire on it for resplicing. coolant pic
Bouncer
Post by Bouncer »
How much for the timing belt cover
Gro Harlem
hrmm...says "error 403 forbidden"
Sorry, you are not allowed access to this file. Try returning to www.mkd.cc
email it maybe? firstgenprotege @ y a hoo.com
DONATE TO MX-3.COM
