Howdy All,
Need the accordian rubber hose between the air filter box and air manifold/sensor. you know the one, the rubber accordian design that cracks and lets air in, causing all kinds of spastic symptoms with idle speed and acceleration. Don't need the resonator tube that attached to it, just the rubber tube. This is for a 93 MX3 GS 1.8L K8 manual trans.
Zip is 96826.
Where is that you say? Think Honolulu.
Thank you much!
GS throttle body air intake tube hose
Re: GS throttle body air intake tube hose
Please notify of part availability by email address: WillCampbell@hawaii.rr.com
My zip is 96826. I need priority mail shipping.
Mahalo!
Mahalo!
I have the one on ebay right now. It fits a GS 1.8L V6. came from a 94. its the same as a 93.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
