Parts wanted. Will pay fair prices.
I had a little accident (you couldn't even call it a fender bender) and some parts need replacing simply because the car (a '92 GS) is 12 years old and rubber and plastic tend to not last that long.I need:a power steering fluid resevoir, two headlights, a turn signal, radiator support pieces, fan with good & straight blades, the rubber duct that goes after the air flow meter/oxygen sensor, the plastic pieces on the side of the seats next to the door and cover the base of the seat belts, and the two opening pieces on either side of the cargo cover in back.
Re: Parts wanted. Will pay fair prices.
Hey, wow, sounds like you are on quite the mission having to look for all these parts. This isnt a fun car to be fixing, but I have the Rubber hose, maybe the oxygen sensor (I'll have to check for sure), the power steering resovoir, and the trunk pieces for you. So if you are interested, send me a message.
it sounds like you need to replace the whole front end, i got all of that , make me an offer and ill pull that, the car is gettin junked soon, reply ASAP
P.S willing to meet half way if u want to pick up those parts
