It depends on if anyone was there to see the balls falling.FlyVFR wrote:If 10 lb and 15 lb bowling balls are released from the same height at the exact same time, which will hit the ground first
KLZE: PGT Vs. MX-3
lakersfan1
- FlyVFR
Then take to a nice flat 7000 ft runway and race airplanesCustommx3 wrote:The Mx3 will surpass 140. Ive rode in 2 MX-3 ZE's and hit 150. I havent tried in mine yet, I'm going to get some good suspension 1st.
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
81 Trans AM NASCAR Pace Car
80 Trans Am INDY Pace Car
www.MyMX3.com Domain For Sale!
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- FlyVFR
lakersfan1 wrote:It depends on if anyone was there to see the balls falling.FlyVFR wrote:If 10 lb and 15 lb bowling balls are released from the same height at the exact same time, which will hit the ground first
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
- XxantwawnxX
Kinda hard to reach 150 when the tranny runs out of gearing at about 140 or jsut before. I have a ze mx and i cant reach 150 because im in 5th gear redline(or just about) at 137-138.
lakersfan1
I believe the 150 is possible with the MX6/626 tranny and delete rev limiter with a rechip or Megasquirt.XxantwawnxX wrote:Kinda hard to reach 150 when the tranny runs out of gearing at about 140 or jsut before. I have a ze mx and i cant reach 150 because im in 5th gear redline(or just about) at 137-138.
- FlyVFR
tatsu already posted figures for top speeds. Now, how quickly the MX-3 reaches point A to point B as compared to the probe should be a declining figure starting at 4% (estimated by tastu) while both cars travel to reach top speed!Amma351 wrote:My bad guys!
I forgot to specify my question, How much faster would the mx3 be?
a car lenght? more?
Thanx
So we'll need to specify the total distance before we can calculate the distance between the two cars and who's in front!
Man I like this stuff
Stock 92 MX-3 GS
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
93 MX-3 GS KLZE
98 BMW 328IS
My Feedback File
Umm...no it won't not with stock tires and tranny. Doesn't matter the power it has, its in the gearing. My Mx-3 wanted to go fatser but couldn't, and i had a 205/50-15 tire/rim combo. ~139 MPH was the limit at 7000 RPMThe Mx3 will surpass 140. Ive rode in 2 MX-3 ZE's and hit 150. I havent tried in mine yet, I'm going to get some good suspension 1st.
Now that i got a bigger rim/tire combo, i can go fasterbut i have yet to try it.
- ovendenk
the fact is that we are approx 350 lbs lighter with approx 4% more torque, so we'd accelerate much faster. in a drag race, we'd win almost for sure. however, in a long distance race they would for sure because they would have a slightly higher max speed because of tire size.
kevin (aka The Oven)
93 mx-3 GS KL-ZE with KL31 cams and properly chipped ecu
All mods are on my website: http://ca.geocities.com/ovendenk
MX-3.com Worklog: http://www.mx-3.com/phpbb2/viewtopic.php?t=48462
hgallegos915
i redline at 7.5 but what for?? youll flat a valve.
-hec
- Aston Wards
in the real world..., the difference would be sweet FA, certainly nothing that a good driver couldn't overcome..... still, it'd be interesting to see!
as for the top speed...., staying in the power band isn't necessary, just as long as the car is producing enough power to overcome resistance..., and on that note..., which has the taller gearing, auto or manual?
91 Eunos Presso KF-ZE
89 Nissan 300ZX TT 2+2
90 Nissan 300ZX TT 2+0
