Changing those big orange indictor lights?
- Hoodzy
STAINLESS STEEL wrote:Basically I want clear side indictor lights like this one
And with the FRONT indicators is it possible to just somehow rub or scrape off the orange tint thats on the inside to make them clear.
theres is no orange on the inside its the bulb reflecting
you can get ones on ebay like mine that are silverstar that are blue when non lit and when they lite up they are orange crazy eh!!! ahah
1995 Creek Mica Blue GS
- jschrauwen
As far as bulbs go, since it appears you like to keep the the appearance of the front turn signals as opague or clear as possible, there is a bulb (1156/1157) out there that has a silver exterior coating on it but will illuminate amber. Can't find that link right now, and will try later.STAINLESS STEEL wrote:Oh yeah, and a change of subject. Is it possible to take the central brake light from the back of, I think it's the Precidia model, and install it on to a normal MX-3 without that brake light?
Wrt rear 3rd brake light conversion, I wasn't aware that the E-Spec MX's did not have a 3rd brake light incorporated. I believe all NA Spec MX's came with the 3rd brake light (US and Canada). If Mazda retained the same wiring harness (which is not always the case) in the rear hatch area, it shouldn't be a problem. And if not, tapping into the rear brake light circuit should pose that much of an issue, however you'll probably need tap into that circuit somewhere near the back seat area as it's routed to the back of the car along the inside of the body panel. From there you'd have to route it to the headliner area so as to utilize the junction port for wiring near the rear window sprayer area. A lot of work, but do-able. You'll also need to acquire the accompanying plastic covering pieces that give access to the rear brake light unit also.
Here's a link to Taras's thread to his 3rd light mod, unfortunately the links to the pics don't work any longer, but an excellent mod, nonetheless. http://www.mx-3.com/phpbb2/viewtopic.ph ... hlight=3rd
Thanks jschrauwen, you've been a great help. Thank you.jschrauwen wrote:As far as bulbs go, since it appears you like to keep the the appearance of the front turn signals as opague or clear as possible, there is a bulb (1156/1157) out there that has a silver exterior coating on it but will illuminate amber. Can't find that link right now, and will try later.STAINLESS STEEL wrote:Oh yeah, and a change of subject. Is it possible to take the central brake light from the back of, I think it's the Precidia model, and install it on to a normal MX-3 without that brake light?
- jschrauwen
No problem, that silver coated bulb info (link) I referred to about earlier is contained within this link, enjoy.STAINLESS STEEL wrote:Thanks jschrauwen, you've been a great help. Thank you.
http://www.mx-3.com/phpbb2/viewtopic.php?t=47578
I got them clear side repeaters from a Mazda 6 and they said......they don't fit!!!mx almere wrote:Use the side indicators from the Mazda 6.
They said they would have to modify the hole, but doing this could make that area more likely to rust, but they could use a zinc primer to try and stop it happening.
What advice would you give me, I didn't really want them to cut anything on the body of the car. Is it possible for them to modify the actual side repeater's themselves, instead of the hole?
