New to COLD climates
I recently moved to Northern AB Canada. And right now we are hitting -30. Both my car and myself are new to these temperatures. I had a look but i could not find a block heater. Do anyone know if the 1995 4cyl came standard with a block heater? I am also having a bit of a problem locating the Thermostat. I can talk the talk but i can't walk the walk, so I want to start doing the little things myself. Any suggestions?
Darcy
Re: New to COLD climates
Check the online shop manual on this site for directions on replacing/adding parts to the car.
I do believe I have an extra block heater lying around here somewhere, but i think Canadian Tire also sells them.
The thermostat is right by the distributor
Thanx Darcy, Best of Luck with that dump of snow you are suppose to be getting down that way.
