SOHC and DOHC tranny the same?
- jumboplay
Topic as question. I'm hitting the junkyard and gonna try to hunt down another one. So sick of syncro problems (my fault but damn it, what can I do now?). And a post that just came up said that certain types of gear oil eat the syncros? Anyone know, damn it I've love to hear about that!
-Tom J, proud MX-3 pilot-
Get your entertainment upgraded at http://www.tommyv2.com
1996 MX-3 RS/GS hybrid, OBDII B6-ZE, painted Mazda crystal white, ZX-2+Eibach, Miglia Spyder 17"s, markerflash, black altezzas, insane fuel economy, too many other mods to list...
- jumboplay
Re: SOHC and DOHC tranny the same?
Oh I forgot to ask...is there another car's transmission I could use? Mine's a 96 DOHC. Some sort of Protege or something? Thanks again guys.
- jaydog5678
Sucks to have transaxle problems, I know.
Make sure the gearoil your using dosen't contain any sulfur. If I understand right, it was reccomended not to use Mobil 1 in some of the earlier G series v-6 transaxles. The PGT guys were complaining about problems when using Mobil. As far as the F series, like the one in your case, I would'nt know if sulfur would contaminate your trans. Perhaps Mazda changed the bronze/brass parts to better materials? A bit more expensive, Red Line oils have NO sulfur, and was highly reccomended by many racers/auto techs alike. I'd try that first.
A 95 Protege trans will bolt directly to the b6 block, however the gearing is slightly taller. You can still use the Mx-3's clutch and flywheel.
- Limegreen mx-3
the sohc tranny uses a long axle on the passanger side. and the dohc tranny uses a half shaft axle on the passanger side they look pretty much the same driver side axle just different axles on the passnager side. but i face a friend who is going to see if the DOHC tranny will fit on the sohc engine. laters
Drifter
Drifter
the jack-shaft does not concern the tranny, just the year of the car. the jack-shaft bolts to the back of the block, so a sohc motor will not have these. you can use the 92-93 axles on any year mx3, but not vise versa
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- Limegreen mx-3
have u check into that before i have both RS's SOHC/DOHC. We look into both of them maybe it will fit maybe it won't who knows tranny bolts up from the last update i heard. I have a 94 driver side axle on my 93 so VISE VERSA my @$$ passanger side thats a different story. latersOriginally posted by OsoSlo z28:
Drifter MX-3
- David Witherow
the 92-93 axles have a smaller diameter shaft that goes into the tranny....you can use them on any year mx as long as they are an F tranny if you put in a G tranny you need to get axles from a V6 mx or protege or mx-6
vise versa my @$$? wow, the maturity of this board keeps getting lower. this was in reference to the passenger side as i was talking about the jack-shaft etc. i'll just leave it at that, you can take it for what it's worth.
it's a proven fact that you can use the sohc PASSENGER side axle with the 94+ cars.
<small>[ August 18, 2004, 09:27 PM: Message edited by: OsoSlo z28 ]</small>
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
- atlantamx3
Ashley knows his $hit... Listen to him.
- Limegreen mx-3
ur right am wrong as for the bolt pattren that the sohc block does not have it does have. but like u said the maturity keeps getting lower i simple don't want to comtribite to that facter. I'll just leave it at that. ur right am wrong and like some other guy said u know ur **** i should listen.Originally posted by OsoSlo z28:
Drifter MX-3
ok, the guy javier was talking about is me. i took a tranny off of a 94 dohc and i'm going to put it in my 92 sohc. hopefully i should get my car back on sat. i will post up any info regarding this topic. it does look exactly the same tho. so far, no probs. oh yeah, thanx javier, you hooked it up bro. if you need anything, just ask man.
save a lung, smoke a honda.
ok, i got my car back today. the tranny is the same and it fits. there is some slight diffrence ( bolts ). you will have extra bolts. obviously, the dohc block is diffrent from the sohc but other then that, everything bolts up perfect.
