PVC cold air intake, looks pretty good...
I made it over the weekend here is pics, http://www.cardomain.com/id/mxredsallad
1994 RS Red 102,200 and Counting
Custom Cold Air Intake w/ Re-Works Filter, 2.25 Custom Cat-Back Exhaust, Dynomax Muffler, Bosch Spark Plugs, Belden Plug Wires, Pacesetter STS, JVC Deck, Yokohama AVID H4 Next - Paint Job, Miata 7 Spokes, Centerforce Clutch
god_of_trash
Re: PVC cold air intake, looks pretty good...
can you please post the sizes of tubes you used...?
I am going to be doing this same idea this weekend... thanks bro!
1999 AWD 20G turbo W/NX nitrous
1995 electron blue r34 kit Prelude
1993 mazda MX-3 stock
The PVC that i used is 3". Heres a list of the things that i bought to make it.
1. 3" Wide 1' long PVC (youll have to cut this piece if you buy by the foot to make it fit)
2. 3" 45 degree bend piece of PVC
3. 2 3" hose connectors.
Depending on what kind of filter you have it will be hard connecting the filter to the PVC, i was lucky enough to have a perfect fit with the original adapter from the filter and the 3" hose connector. (Sorry if that was confusing)
Also they measure the inner diameter of the pvc to 3" the whole pipe from mine was 3.5" with the sides.
Sorry if its confusing but it will all come together when you buy the stuff.
Oh and last the total cost without the filter was around $15, beat that PRM.
