BPT non-intercooled..
cris_barros
Post by cris_barros »
Can I run a BPT without an intercooler(just for a few months,at veeeery low boost, until I get my intercooler)??
And with my stock F25M-R tranny?
Any info is welcome..thanks a lot guys!
Cris
Re: BPT non-intercooled..
Post by Josh »
you can but it is highly not recomended. i did and blew out all my berrings in the stock B6, but i dont think that it had anything to do with not having the IC, i think it was an oil additive i put in. i only spent 50 USD on a front mount ford probe IC at my local wrecking yard. iv heard you loose about a pound of boost on average going threw an IC but you gain HP from it.
mx3man83
Post by mx3man83 »
If you lose boost through your intercooler it's a good thing. All it means is that your air is being cooled.
My Cardomain site
monty73741
Post by monty73741 »
plus a front mount intercooler looks bad ***
<img src="http://images.cardomain.com/member_imag ... 4_full.jpg" alt=" - " />
<small>[ January 24, 2004, 08:57 PM: Message edited by: monty73741 ]</small>
Jason Danaher
Please Help Support MX-3.com
cris_barros
Yep..I know! :(
So, the question is just that..can I put the BPT without an intercooler for a few months?? (again: I'll not drive hard, it's not my daily drive, and I can even shift at only 2000RPM, without spooling the turbo...)
Thanks again!
Cris
Freq2002
Post by Freq2002 »
Cooling the intake charge lowers the occurance of detonation as well as ramming in a greater mass, thus making more power.
You can run any turbo system without an IC, but you have to watch for detonation. An ECU or piggy back with a knock sensor, or just proper tuning & running higher octane can help avoid that.
I know of many many cars out there running right off the turbine, it's all in the tuning.
The contents of this post are the opinions of myself and are NEVER meant to be percieved as the "be all, end all". So cram it!! :p
plusinfinit
Post by plusinfinit »
Yes you should be able to run a turbo without an intercooler. But you have to watch your RPM and your knock just like that guy said. I am not sure but maybe u can retard your igniton a bit, again i am not sure if that really helps. High octane gasoline is a must with a turbo and you should be thinking about geting an oil cooler. I know for fact that some older turbodiesel cars in europe run with no intercooler, but than agin they are diesel.
StPapp
Timmyd865
Post by Timmyd865 »
WHY WAIT FOR ONE TO ARRIVE?!?! Just go find a Mx6/probe/626 intercooler. They're BIG and effiecient. WAY better then Mistu IC's. They're easy to find and cheap! GO GET ONE! It's not worth risking ur engine non IC'd. Just go do it!
16" Sport Edition Fox 2's, Yokohama H4's, Eclipse CD player, Eclipse components, MTX amp, Lightning Audio woofers in a custom fiber glass enclosure, custom intake, factory spoiler installed, reverse indiglo gauges, custom switch panel<p> :) www.geocities.com/timsmx3
Post by Josh »
its because he lives in Brazil. im sure parts are alot harder to come by at a local wrecker. than in the states or canada
Timmyd865
Post by Timmyd865 »
Good point :) EBAY!... u can probably get it in a week. Peace!
