Cross Drilled Rotors?
- The_Great_Tonge
some guy in the chat room were talking abou rotors from a 92 civic i think that would fit on the mx. has anyone tried it out? just wonderin cause i swear i heard my brakes yesterday, so i might need to replace em and there is nothing like some cross drilled action
Re: Cross Drilled Rotors?
Come on now Adam, Slotted are better. Cross drilled will eventually crack under the stress, but the slotted will hold up long and are just as good.
As long as you can find someone to turn them properly for you when the time comes. Stock rotors with good pad,(Hawk, etc.) will stop you just as well with the speeds the MX3 creates.
pull hard,come easy. Second gear is hard at 7300
