Fan issue
Aaron MacDougall
Fan issue
Sold my car but an ongoing issue I've had for the past while still isn't resolved and i wouldn't mind giving the guy who bought the car some info on fixing it. <p>Problem is that my fan will not turn on when my car heats up...<p>In the last year i have replaced the thermostat, Temp sensor on the block, Fan assembly and electric motor. If i hook up the fan manually it works like a charm but it will not turn on when the car heats up at all. Any info would be greatly appreciated and will be passed on to my babys new owner.
Re: Fan issue
Aaron I had same issue, it has been fixed. However not by me, I will ask my friend that fix it exactly what he did for you
Re: Fan issue
take apart the plug and see if it;s all rusted mine was so i just got a little file and got it to the metal again and it works fint
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: Fan issue
The fan in my GS never turns on at all, but the engine stays nice and cool. Maybe its not a problem...Does ur temp. gauge go above halfway up?
My Cardomain site
My Cardomain site
MX3chicago
Re: Fan issue
i made it easyer then all u did I unpluged the harnes which is by the fan got 4 MALE connector plug thingys ----(((( and stuck it in ran wires to the interior of my car n one to the ground and made 2 switch's in my ****pit so i turn them on any time i want to i reversed one so it blows the hott air out the one closest to the exhaust manifold is reversed so it sucks the air OUT thats what i did n my car runs cool so then boost's power a lil bit
Re: Fan issue
lol....
92 red rs
performance exhaust
zx2 struts and Eibach springs
turboed + stand alone when the cash is there
Aaron MacDougall
Re: Fan issue
I had the fan wired to a switch for a while now but the new owner would like it resolved. I was told by Mazda that the mx-3 would have to temp sensors, one in the block by the thermostat housing and one in the rad. and the one in the block has been replaced. If i did't switch on my fan manually it would heat up over the half way mark.
vegetoking
Re: Fan issue
did u ever fix this problem?
- Limegreen mx-3
Re: Fan issue
am having the same problem replaced the themastat flush out the cooling system all new antifreeze. my temp guage still goes up and down when i nail it an no fan power. probly the sencer pissing me off.
