noise??
spllogics
noise??
Post by spllogics »
Hey guys , i have this slight grinding noise i hear wheni let off the gas .. has anyone had this problem before.. i have a 4 cyl automatic... thanks
white94mx3
Re: noise??
Post by white94mx3 »
Hmm, that's strage. You should check your transmission flud, cause it could be low causing the gears to grind a bit when it downshifts or you could check your transmission cooling system. Other than that I'm not sure.
1994 Mazda MX-3 RS (Project RS-T)
spllogics
Re: noise??
Post by spllogics »
thanks , ill get it checked out tomorrow ..
Guest
Re: noise??
Post by Guest »
it might be some vibration or the heat shield, but please get it checked out..if its the tranny and u leave it unattended u will pay $$$$
spllogics
Re: noise??
Post by spllogics »
i checked the tranny fuild and all it seens fine.. also the car has a lil jerk about 55- 60 mph..
white94mx3
Re: noise??
That's Strange... Did you check The transmission Cooling? Cause Automatics Require Cooling or else they might not run correctly... or it Could be the firewall jittering or somthing like that, BUt the Jerk at 55-60MPH...I'm not to sure about that, I have a 5Spd so I can't really tell you that by experience. [img]shrug.gif"%20border="0[/img]
spllogics
Re: noise??
Post by spllogics »
? where is the tran. cooling ? i looked but couldnt find it. or is it the same as the fluid? thanks guys
white94mx3
Re: noise??
The Transmission cooling runs from the radiator to the transmission through to small lines 1. Input, 2. output
