Innovate LC2 wideband install question.
A section dedicated to Engine Mangement Systems & Engine Tuning. Megasquirt, SMS, Haltek, ect.
95_MX3_RS
Post by 95_MX3_RS »
Hello,
I've got my bung welded on for my wideband, I now need to run the wires into the cabin.
Any suggestions? I'd like to go in near the shifter. I considered making a small hole in the gasket
around the shifter assembly and running the wire through there. I don't run the car in the winter, so if
there is a good way to keep the wires away from the exhaust and shift linkage I don't see a problem with this.
The other alternative would be to drill a hole into the floor with a grommet under the console. I don't think the
wires are long enough to reach up the firewall and through the usual way.
-Ben
WhiteFinish
Re: Innovate LC2 wideband install question.
Post by WhiteFinish »
mine went through the firewall long enough
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Return to “Engine Electronics/Tuning”
