klze/klde stroker kit?
- SpatialTerror
i was looking around on some of the other forums and they said something about a company that used to make stroker kits for the klze and the klde.
i think it would be cool to stroke out my klze.
does anyone on here have a stroker klze or klde?
and if so where could i get one?
93 GS-R with crank pulley racing clutch and flywheel, magnaflow cat back exhaust, short ram air, 12" rockford fosgate p2 subs, on a amp 500rms, jvc touch screen deck.work log --->http://mx-3.com/phpBB3/viewtopic.php?f=46&t=75217
92 RS with lowering springs, and body kit.
SpatialTerror
SpatialTerror
Re: klze/klde stroker kit?
I would like to know this too!
						- Josh
I have the link saved somewhere. But from what I recall they are like 3500-4000 USD
http://www.paeco.com/Stroker%20Kits.htm
MAKE OF CAR _____________ | ORIG. DISPL. ___ | STROKER DISP. | OVERBORE | STROKE INCR. | PRICE/KIT
MAZDA MX-6/FORD PROBE V-6 | 2496CC ________| 2715CC _____ | .040" ____| .250" ______ | $2,299.00
- kulluminati777
yikes!!! i wonder what the real dyno numbers look like. that much money i want 60+ HP on the ZE.
						- mitmaks
I can get stroker kit for my 440 Charger for less than that, what a rip off.
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
- MrMazda92
There was another stroker kit available for less, using Honda rods/pistons, and an offset ground crank. I believe it was in the ~1,800 price range. Not a lot cheaper, but something to think about...
Supply and demand...mitmaks wrote:I can get stroker kit for my 440 Charger for less than that, what a rip off.
How many stroked KL's do ya see around?
- mazda915
http://www.graveyardmotorsports.com/K_S ... _s/782.htm
heres that link best guys to build you a race motor k series. But. Money talks they are expensive and you get what you paid for . These guy's are the best and iv seen there work til this day engines from them still running hard and strong .
1992 gs k8ze . 4 inch tip 2.5 cat , cold air  intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
