I'm sure this has been covered many times, but at the risk of getting flamed, im going to ask some tired questions, haha.
I have recently picked up a '96 MX-3 GS with a 5spd . It has 160 000km and a blown up K8 - i got it for 300$.
So, my options are :
Spend lots of money and time rebuilding the K8
Spend less money on an MX-6 motor from pick and pull. (no K8's to be had locally)
or Spend lots of money (1000$) on a KLZE .
I'm trying to talk myself into the KLZE before someone else buys it. It's an OBD1 motor with the straight neck intake on it, but it also comes with an OBD2 KLDE manifold. then there's the stock K8 manifold as well. Which should i use? The curve neck one is the easiest to Physically use, because theres no brake booster mod, correct?
then what ECU should i use with it? I assume i will need an ECU from a KLDE , and a matching VAF? this motor doesnt come with a VAF as far as i know. From what i've read so far the K8 ECU doesnt work well with the 2.5L KLZE ? or is it not that bad.
is using a different ECU just a plug n play deal, or is there splicing involved to make it work?
funny the more i read the more confused i get. i'm trying to minimise wasting money on unnecessary parts, but also would like to pick everything up at once, since the junk yard is over an hour away from me. That trip gets old quick..
any links to good build threads would be greatly appreciated
