144,000 miles on rust free body w/"fresh laguna blue paint"
2.5L JDM KLZE swap - "doesn't burn oil or smoke", no color under valve color indicating very "low mileage" purchased from
JDMEnginecorp in Texas-engine runs very smooth and has no knocks or HLA noise etc. I've maybe put 5000 miles on it since ownership due to wrench time and being a seasonal car.
KL31 cams
Millenia Curve neck intake manifold
Millenia KL47 throttle body
Proper j-spec KL31 ecu
New timing belt kit, tensioner and water pump.
New O2's, crank sensor
New plugs and NGK wires
Corksport Bronze Oillite shifter bushings
Resurfaced K8 flywheel and new stage 1 clutch done at time of engine swap
There's more, but just ask any questions you'd like. "More pics upon request"
Things on car that don't work are the ac , horn and cruise
$3250.00 "member price"
