Q1: I'm staying at my g/f's parents place and was replacing my spark plugs & brakes... Her dads a know it all and pretty much pushed me aside from my own car when I was doing this, so I have to ask since I've never seen it... Should your spark plugs be screwed in tight enough that you're using a torque wrench to put them in? <--- Seriously Concerned...
The above mentioned question was about 4 days ago, since then, I don't know how these two could possibly be related but I'll give a few things that I think my help as well.. I work at Wal-Mart, thus, my pay rate is bringing pretty much from paycheck to paycheck without much room for excessive spending... but I hope you trust me in the fact that I have dreams for this mx3... as it's my second... and it's treated me better than most women I've dated... I digress..
In order:
Q2: Headed home from work, speed limit is 60, so around there... (I've been losing gas milage as well... I have a stock 4cyl...) Check engine light comes on. I stop at a gas station, and just to see if something was serious since I've never seen this... I cut the car off, disconnect the battery (not sure if this was a bad idea, but... I did it.. can't take it back now) plug it back up to reset the light, and it hasn't returned.... yet... upon finishing my journey (off the highway now), anytime I'm turning, as I shift in neutral, my car starts idling on it's own to approx. 2-2.5 rpm's on it's own... Which it does from time to time (on this journey).. Though of course, I'm testing and notice that it's almost guaranteed to happen if I press the brakes when I take a turn... I don't know how the engine light can correlate to the revving, but I figured if anyone could help, it would be someone on here.. And I'd rather ask you guys before I ask you know who...
Things I can tell you:
-It's been about 5k since my last oil change..
-Of course, the possible spark plug question...
-I've replace the fuel filter, but it's been awhile...
-There's an aftermarket intake on it... (with my lack of knowledge, let me clarify by saying... it's got a big a** open filter that hisses that I've been told is an air intake)
(I've never changed it in the 40k I've put on it...)
-New tires
I'm not good with terminology on cars, but I'm really trying to learn...
Final question that's not an issue...:
Q3: It's a 5 speed. Shifter rattles, kind of annoying... Rather loose. Am I missing something that holds it steady?
I know I made it longer than I should have, but I hope I didn't bore you... Thanks for any help in advance, I really do appreciate it, though again to be honest, I'm glad one way or another I remembered to ask you guys before I asked Mr. Expert... Since thus far, you all have never steered me wrong...
