My 94 1.8 is leaking gas by the tank, only when its near the top.
The culprit isnt the filler neck or tank its the 2 parts bolted on to
the filler neck, one is a metal bag & the other a metal tube that are
all rusted out. I believe these to be part of emmision control system.
Lots of hoses into em...
My problem is that when I go to the dealer we cant seem to find these
parts listed.
anyone know exactly what they are called or part #s, Im pretty sure I wont find
these good used wherever they salt the roads.
Thanks
Leaking Gas
- Daveb
Leaking Gas
1994 GS 5 speed 1.8, fresh black paint, flowmaster muffler & Little smelly pine tree
1993 RS 5 speed SOHC with 89,000 original KMs! (rising fast though).
1994 RS 4 cyl auto- running parts car with 104,000 KMs
Re: Leaking Gas
I'm not sure what you might be talking about with reference to a metal bag. There are a couple of valves.
You might be able to identify the parts using the service manual link.
You can use this link and site to get the Mazda part #.
I had a similar small leak (different car) when fuel tank was full problem that I found to be the fuel pump filler bracket / cap had rusted out. You can check that from inside the car by removing the back seat and an access panel.
- Daveb
Re: Leaking Gas
Its not on the first link at all
Its not really part of the fuel system, its like a return system.
I believe its part of the evap system. Thier are 2 main parts with lots of rubber hoses
bolted on too the filler neck, if I remember correctly.
1 part is like a metal bag, sort of woven looking...I may try & take a photo, maybe my
mate in Calgary can find it at pick-a-part ?
anyone know what there for MX-3s or a better place, It will have to be from a salt
free environment. plastic cover over the whole mess..
Thanks
Thanks
