The other bank turned out to be flawless, with perfectly smooth cylinder walls and no piston damage. The build will carry on, without the need to source another bottom end.
I like!!
  Budget build, FTW.
 Budget build, FTW.
 Money is tight, and only became tighter when I became a father earlier this year.
Wiseco has a bunch of options, 8.5, 9.5, 10.2 and 11.5 compression ratios, all available in standard, 20 and 40 over...MrMazda92 wrote:The block is being dropped off tomorrow, and I am debating exactly which set of pistons I would like to go with currently... I would prefer to avoid both dished and domed pistons, but so far as I know the flat "ZE" pistons are not available in oversize.
