So everything was working fine then I blew a cam belt.
Changed heaps of stuff while car was out of action.
CAI, did a HEI + Coil and changed to curve neck intake on my ZE. I would have tugged at the wiring loom to relocate some things and I did stat the car with HEI + coil without a resistor a couple times. Resistor is in and tach works fine, I can see my revs no issue.
Just a dead speedo.
Any ideas, where should I look?
It's a 1995 Eunos 30x (mx-3 GS).
							Speedo Dead
Speedo Dead
1995 Eunos 30x KLZE
				crazycanadian
Re: Speedo Dead
Speed sensor wiring from the transmission up to the cluster... its 2 wires off the sensor and they feed directly to the cluster.. you have 3 possibilities.. dead speed sensor, bad wiring, dead cluster.. take your pic..
						Re: Speedo Dead
Thanks for the fast reply! Do you know whereabouts the sensor is? I know of 2 gearbox sensors but I thought one was a neutral/clutch switch and one was a reverse switch? Or is there one more I don't know about?
Thanks again for your help!
1995 Eunos 30x KLZE
				crazycanadian
Re: Speedo Dead
On top of the diff by the passenger side axle...
						Re: Speedo Dead
Thanks, found it.
It was possibility 4: forgot to hook it up like an idiot.
1995 Eunos 30x KLZE
