okay my car was running fine yesterday its been raining i dont know how that effects it i had a few problems to sort out today with the car now down to the real problem
my car wont start assuming because the distributor and i can bypass this with an MSD coil which i have and something called HEI or an MSD box ive seen the msd box in the store
do i need either box to bypass the distributor or can i do it with just the coil?
now if i do need the box or a hei box what would be the correct connection diagram.
another question was is there another distributor that i can put in? its a 4 cyl and its a 1.6L but if there is a more powerful one i can put in and i NEED it for the mod i will get it. or if there if one and i dont need it i wouldnt mind looking into how to tie that into the wiring harness if that was a possibility
HEI/MSD box. car wont start need to bypass dist
- wednesdayslatest
03 Dodge Neon (rental i had for a month but i ran that into the ground for sure)
95 Chrysler Concorde (Junked my first car [still ran])
90 Nissan Stanza (Junked [wouldnt start one day])
89 Saab 9000 CD (sedan/turbo very fun but electrical problems[city towed away for no plates on private property])
94 Toyota Camry (mothers old car fixed it then broke it[dont ask] Junked)
93 MX-3 RS (My project for 3 years so far)
97 Honda Civshit (Beater/Stereotypical POS Honda im fixing)
Re: HEI/MSD box. car wont start need to bypass dist
Use the Search function and in the FAQ section type in HEI. viewtopic.php?f=23&t=69006
