Alternator rebuild
MrMazda92
Re: Alternator rebuild
Post by MrMazda92 »
Everybody loves getting a unique haul from the junkyard, when we're lucky enough to do so! :wink:
Dan, I'll probably cut the wiring for the plugs themselves, and worry about pulling the connectors when I get the engine home. :) I'll be able to take my time with it then, since I'm already tearing into it anyways. :mrgreen:
Post by Josh »
Contact Romaine Electric http://www.romaineelectric.com/page4.html there is one in Wenatchee
I just rebuilt mine yesterday, they had all the parts on the shelf.
mitmaks
Post by mitmaks »
Demonic1 wrote:
Nd4SpdSe wrote:Why not just swap for the Millenia alt?
Junkyard Millenia alternator, millenia rebuild kit.
Higher amp and probably better reliability.
The mitsu units are garbage. (And one of the next peices I'm swapping out)
Millenia alternator is 90AMP just like mx-3 isn't it?
Demonic1
Post by Demonic1 »
The KJ and KL had 110 amp alternators in them.
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
Earlier Millenia's had the 110, but apparently they went down to 90amp in the later years...
MrMazda92
Post by MrMazda92 »
Nd4SpdSe wrote:Earlier Millenia's had the 110, but apparently they went down to 90amp in the later years...
This is true... I've found three 90 amps and one 110 so far.
Post by Josh »
They only went to a 90amp in like one or two years of production. I pulled mine from a 00'. I want to say 97-98 has 90amp.
