Hla noise
- sinix3
Hla noise
Ok so my car has been running great up until yesterday i noticed a sort of rattle when i rev the engine and when its under load . I was just reading somewhere that it could be an injector tick so im confused. It's really weird. Any ideas my fellow mx3 lovers. Oh and iv done my klze swap by te way
92 mx3 gs klze swap.
"nitrous is like a hot chick with an std you know you want to hit it but your afraid of the consequences"
Re: Hla noise
How's your oil? IF you're close to oil change time change it nad toss in some lucas oil stabilizer. If you just changed the oil when you did the swap, did you put the right oil in?
I was dumb and put in 5w20 without paying attention which caused me to have maaad ticking till I changed it out.
- sinix3
Re: Hla noise
I changed the oil when i did te swap but i just changed the oil around 9-1100 km ago and i was tuning 10w30 brek in oil now im running 5w30 would that make the difference?
Re: Hla noise
Ticking could be your lifters, check where exactly the ticking is coming from. If it's from the passengers side rear of the engine it's probably your timing belt tensioner allowing the belt to slap. You can put a long screw driver to the engine with the plastc end to your ear and further identify where it may be coming from. Of course if it's across the entire top of the engine then ignore this post.
- sinix3
Re: Hla noise
But could my oil be to thin?
Re: Hla noise
The first number for oil "weight" is viscosity at 0C the second number viscosity at 100C. I believe the manual specifies 10W30. If the oil you're using has 30 at the end it is Ok.
Re: Hla noise
Mine had a rattle for a few days then I drove up a hill and the engine died silently.
Hydraulic tensioner gave way and made a mess of the belt.
1995 Eunos 30x KLZE
Re: Hla noise
Does the noise come and go?RX8SE3P wrote:Mine had a rattle for a few days then I drove up a hill and the engine died silently.
My tensioner would only make noise at idle and to 2500 rpms...then it would go away.
You may also have a exhaust leak....If it was small..you would only hear it under load.
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
Re: Hla noise
Yes, I heard it at idle mostly in the morning when starting. But it didn't do this for long before it ate the belt!
1995 Eunos 30x KLZE
