will this fit? Wheels/Tires
windofire
Post by windofire »
hey guys :)
i've bought a set of 17x8" ET 40 wheels and would like to put on a set of 235/40-17 hankook v12 or eagle f1 tires, does anyone know if those would fit without rubbing?
i've got coilovers so i have a bit more space.
Black Mx3 GS
ZE swapped with kl36 ecu and Exedy oem clutch, Fidanza flywheel, 2.5" stainless exhaust, Ebay headers, 8mm sparkplug wires and Denso iridium sparkplugs, Rockspeed CAI, 17x8 wheels, 235/40 Goodyear eagle f1 as, Taroc japan sport discs and pads.
AaronTietje
Re: will this fit? Wheels/Tires
Post by AaronTietje »
Good chance you will need to space it out. As far as the 235 goes, I'm thinking it will be close.
WhiteFinish
Post by WhiteFinish »
Seems to be a very tight fit, don't know if you can still turn your wheels to the maximum.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
kulluminati777
Post by kulluminati777 »
u may not be able to turn the wheels to full lock to lock. I couldnt. But i had 18x8 on 215 35 tires. Plus u have coil overs so you wont have to worry about rubbing on the wide struts. You may be rolling your fenders though
youdirtyfox
Post by youdirtyfox »
I don't think they will tbh, you don't want to rub away that fuel pipe at the back like Mooneggs did, good choice on the F1's though!
windofire
Post by windofire »
thanks for your answers :)
currently they are fitted with 215/40, but they are bad because the previous owner had an agressive camber, and i've got about 1" of space when its turned all the way over to lock.
i was allready thinking of roling fenders as i have to do some rust on both rear fenders.
i've ordered the eagle f1 asymmetric, if they dont fit i'll make them fit :P
youdirtyfox wrote:I don't think they will tbh, you don't want to rub away that fuel pipe at the back like Mooneggs did, good choice on the F1's though!
thanks for the warning, i'll make shure it doesn't rub :)
Black Mx3 GS
windofire
Post by windofire »
a little update'
the new wheels are fitted, only problem is rear fenders rubbing the tires when going over bumps :?
but that problem can be fixed by bending the the rear fenders inner edge upwards 8)
the ET on the rims is 35 not 40, my bad. but they fit allmost flush :)
Black Mx3 GS
