I have had a very productive week so far
MazdaSpeed6 calipers and the Probe front spindles I'm using for the conversion are sitting on my living room floor.
They definitely bolt up 100% perfectly, although I am planning to replace the wheel-bearings before installing the setup. I'm going to head up to Portland this weekend to pick up my FD wheels, and then I'll start reducing the profile of the calipers to clear the wheels.
I replaced my bent strut in the left rear, and am still trying to get ahold of the rear spindles I need... I'm debating exactly what setup I want to run in the rear. I'm torn between Lantis rears and MSP rears... If I can't get something relatively cheap soon, I may suck it up and use the MiataSpeed rears and use Protege 5 lug hubs on MX-3 spindles... I hate how the Probe rears are setup, so I'm considering importing Lantis rears, or making another setup work.
The last thing I did was snag a weighted Mazda 3 shift knob for $1 from the junkyard. PERFECT condition, the car arrived 30 minutes before I pulled it too!
I did take the time to measure and compare 1st gen AND 2nd gen Probe front spindles to MX-3 fronts today. I ended up buying both the 1st and 2nd gen fronts from the junkyard to take measurements and pictures for everybody.
The Probe front spindles are 99% identical between the two generations, the ONLY difference being the rear protruding arm that connects to the tie-rod ends. The 2nd gen spindle is thicker in that area, while the angle and length are perfectly identical.
As the Probe spindle/hub combination sticks out almost 15mm farther than the MX-3 stock configuration, I should be able to maintain a gap between the FD wheels and the strut perch with thin spacers, if any are needed at all.
I'll be documenting this entire process, and making a full write-up for everyone...
