if i cut the plug off of my k8 knock sensor and solder it to the knock sensor on my KLDE will it still work effectivly??? would crimping it work????
i didn't get the male plug end when I got the KLDE and noticed just now with engine in car that the plug heads are different.
so:
1) cut k8 female plug
2)cut KL female plug
3) solder K8 female plug to KL knock sensor
4) plug it into my mx3 wire harness.
this is a v6 swap
only qualm is that when i cut the k8 plug, i noticed insulation, some wire, insulation, and another wire on the inside.
KL knock sensor plug is different from k8???
- mikeetown
mikeetown
93 Black GS - J-spec KLDE, CLEAN CAR
92 Red GS - J-spec K8ZE, stripped interior - Written off
2004 Infinity G35 Track Edition - 6 speed manual
viewtopic.php?f=17&t=79142
- MrMazda92
Re: KL knock sensor plug is different from k8???
Bolt the K8 knock sensor into the KL block?
http://www.autozone.com/autozone/parts/ ... 95822_0_0_
Same sensor, why waste your time? I think your looking at a different sensor plug dont forget KL knock sensor wire is routed to the opposite side. Simply remove intake manifold and position plug connection on proper side and reattach intake. Done. Ill take the $$ from the labor time in my paypal for college payments please
